I am trying to create an ADA Door clearance rectangle, and depending on the condition of the door (push, pull, side approach, and ext), the rectangle will change automatically with the door size. I tried a few different ways and landed on making a nested family and making the clearance rectangle a separate family from the door itself. I managed to change the clearance rectangle's length since it is a good solid number. However, when I am making the width parameter, I encounter issues when I want to make one type of rectangle width with "=door width" and the other "door with + 18" " (door with will be hooked up to the actual door width) Revit doesn't allow me to do that and want to make the formula the same under the same parameter even under different type.
I guess this might be a dumb question, but is there no way to have different formula even under the same parameter since we are working in a separate type? Also if you all have any other ways to approach this issue you are welcome to follow up on this.
