Parameter Formula Different From Different Type
DanielleZhang
Message 1 of 12
DanielleZhang
I am trying to create an ADA Door clearance rectangle, and depending on the condition of the door (push, pull, side approach, and ext), the rectangle will change automatically with the door size. I tried a few different ways and landed on making a nested family and making the clearance rectangle a separate family from the door itself. I managed to change the clearance rectangle's length since it is a good solid number. However, when I am making the width parameter, I encounter issues when I want to make one type of rectangle width with "=door width" and the other "door with + 18" " (door with will be hooked up to the actual door width) Revit doesn't allow me to do that and want to make the formula the same under the same parameter even under different type.
I guess this might be a dumb question, but is there no way to have different formula even under the same parameter since we are working in a separate type? Also if you all have any other ways to approach this issue you are welcome to follow up on this.
Replies (11)
Message 2 of 12
Hard to visualize what you are describing. In part though, it sounds like a description of nested IF statements.
Can you share any screenshots or the family itself?
Message 3 of 12
jvpantin2
Hi, @DanielleZhang, "door width" is a type or instance parameter? Remember that instances parameters are unable to be used in formulas, normally a warning appears indicating so. If this were the case, you should convert it to type parameter in order to work properly.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Message 4 of 12
@jvpantin2 wrote:
Remember that instances parameters are unable to be used in formulas.
What do you mean by this?
Message 5 of 12
DanielleZhang
NV my other Revit Buddy came and resolve the situation. We just added another parameter so the formula can be the same. Thanks anyway!
Message 6 of 12
jvpantin2
@barthbradley, sorry, I didn't complete the sentence:
instance parameters are unable to be used in (type parameter) formulas...
Message 7 of 12
Hmm,  I have Door Width as a Type parameter and all ADA dimensions as instance parameters since forever.
Message 8 of 12
jvpantin2
Whenever I tried to extract value from an instance parameter to a type parameter got that message 🤔
@ToanDN, you are using them backwards (from type to instance) and so it works...
Message 9 of 12
Maybe you don't understand OP's intent.
Op's question is to have Door Width as Type parameter and ADA clearance as Instance parameter.  The type parameter Door Width + other conditional statements drive the value of the instance parameter ADA clearance.  Why would anyone want it the other way around, which is using the clearance to set the width of the door?
Message 10 of 12
jvpantin2
@ToanDN Maybe I don't, but asked @DanielleZhang for the kind of parameter (type or instance) in case it were the cause of her trouble. And because once I went mad trying to use (by mistake) an instance parameter to add value in a type parameter formula. That's all.
Message 11 of 12
RDAOU
Hi @DanielleZhang
While the argument about who understood your question and who didn't continues, it might be a good idea to mark your reply quoted above as a solution.
Message 12 of 12
DanielleZhang
All, thank you for your responses. But what I did was literally add another parameter to input the required ADA clearance distance and put that parameter in the formula so it's consistent. For example:
Parameters: Width, Door Width, ADA Clearance
Original Issue: Width = Door Width + # (the formula have to be the same for Revit parameters. you can't have Door with + 4 for one type and Door width + 0 for another)
Solution: Width = Door Width + ADA Clearance (A variable where the number can be different for each type, ie type 1 ADA Clearance = 4 and Type 2 ADA Clearance can be 0, the formula does not change and we achieve the same output)
