export DWG separating line and hatch layers
1 ANTWORT 1
Nachricht 1 von 2
Rodolfo_Bringel
239 Aufrufe, 1 Antwort
Hello, friends.
I have a question: is it possible to configure Revit's DWG export so that hatches come out in a different layer than the element's contour lines?
For example: a beam with the outline in blue and the hatch in gray (images below) is exported with the correct colors, but the lines and hatches are in the same layer.
I would like the lines to be on a different layer than the hatching.
Beschriftungen (3)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Rodolfo_Bringel
Only for Walls, Floors, Roofs, Ceilings categories.
