Parameter for "top of window"
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
I'm trying to create a parameter that reads "Sill Height" + "Frame Height" so that I'm able to read "Top of window" (from floor). But I haven't found a way to achieve this (can't read "Sill Height" inside the family editor), any tips?
bimscape
Just create a new Length parameter and use a formula within the Family, to add the other two parameters together.
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Marcus.Isacsson
But I can't add "Sill height", the family just contains "Default sill height"? 😕
ahmadfiroozi000
You can edit the window family and add this parameter, "share parameters" is better.
The Window Instance Properties in the Project reports both the Head Height as well as Sill Height.
Marcus.Isacsson
Embarrasing, found this parameter after a while. I blame the sea of parameters we're using 🙂
