Issue with parameter and label
arkitekt_melber
arkitekt_melber
Hei, I want to make a sheet family with label in the title area. The problem is that when this is loaded in the project I am not able to modify this label. I can see a "?" but I am not able to modify it. Some label are working ok but the label where I created new parameter are not working. I have created similar project parameter in the project but still does not work. The project look like to also have the same shared parameter but it does not help. So I don't need som hjelp to find out whath I am doing wrong.
bimscape
It needs to be a Shared Parameter- so that the value can be accessed in different areas of the software (ie Sheet List, Titleblock Family, etc)
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
ahmadfiroozi000
You should add these parameters in "share parameters".
Some labels only show in this.
