Panel Schedule BLANK - Transfer standards NOT WORKING
Xion_arq
Message 1 of 14
Xion_arq
Hello.
Anytime I try to create  panel schedule is in BLANK. I've already created a new electrical project and transferred the standards (panel schedule: Branch panel) a hundred times, and still not working, the panel is still in BLANK. I even opened an old project of mine with panel schedules perfectly working, transferred the standards, and nothing.  I need help!
Replies (13)
Message 2 of 14
Tom_Kunsman
Do you have any loads applied to the panel?
Message 3 of 14
Message 4 of 14
Xion_arq
Yes, As I commented, I even transferred standards from previous projects were I created panels.
Message 5 of 14
Xion_arq
Yes.
Message 6 of 14
Did you choose a Template that you Transferred into Project?
...if not, right-click on the Panel Schedule you created in the Project Browser and select "Change Template".  Then select the Template to apply.
Message 7 of 14
Xion_arq
Yup, still in Blank. I even re-installed Revit last night.
Message 8 of 14
Let's see your file. Post it here.  In fact, post both files: the one you're working on and the one you're transferring schedules from.
Message 9 of 14
Xion_arq
Here you go. I hope you find something
Message 10 of 14
Transfer Project Standards from the Multi Discipline template and use the panel schedule template below:
Message 11 of 14
No issues here with either Project.
REPORTING SOLE PANELBOARD IN A-2024-06-2531 EAGLE-JUNE-06.rvt:
Message 12 of 14
Xion_arq
Could it be my Revit? Or maybe view settings?
Message 13 of 14
I don't know how.  Are you OVERWRITTING when using TPS?  Maybe you're not. That might explain the problem.
Message 14 of 14
yes_and_no
