panel not showing right
roscopeco2000
roscopeco2000
Hello I am modelling a building which is a steel frame with profiles steel panels over the top why when i download the BIM object do i just see a block? in the preview window it looks like it should have more detail
dzanta
from the image...it looks like a curtain panel that was created using the extrude command.  The profile is a rectangle that is extruded up to create the rectangular panel you see.  If you are trying to make a panel in which the profile is different (such as metal decking turned vertical), edit the extrusion profile the show the panel undulations and then finish the extrusion.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
roscopeco2000
i think you misunderstand this is a manufacturer created product and should looks like below.
dzanta
i see....try changing your level of detail to fine....they might have created it to look basic in Coarse or Medium level of detail.
roscopeco2000
its set to fine here is link to the object..
https://bimobject.com/en/tata-steel/product/trisobuild-wall-hori
dzanta
i downloaded and looked at both the roof and wall system families.  These are basic walls and basic roofs.  You cannot create a corrugated wall or corrugated roof panel system using these two system families.  In order to create the walls/roofs to look like they are corrugated, then you will need to use the curtain panel system and create a custom profile for the panels.  See the following video for the workflow:
https://www.youtube.com/watch?v=nG72bYJGKfQ
Hope this helps.
Their model is a means to provide the technical data for scheduling and/or exporting to IFC.  For a lot of projects, this is more important than modeling the corrugated panel just for the look.
