Revit 2016 updates
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
sureshchotrani
1690 Aufrufe, 4 Antworten
Revit 2016 updates
I am not able to find below Revit 2016 update in my account, I can see upto Update 7
Update 8 for R2 (2016.1.8) 16.0.1205.0 20170117_1200
Is it there or rolled back?
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
4 ANTWORTEN 4
Nachricht 2 von 5
DarrenP
als Antwort auf: sureshchotrani
i am not seeing a update 8 for R2 for revit 2016
only seeing update 7
DarrenP
Nachricht 3 von 5
Tony_Michniewicz
als Antwort auf: DarrenP
Revit 2016 R2 Update 8 only impacts the collaboration workflow and therefore has not been made available through the Autodesk Desktop App or the Autodesk Accounts Portal.  This update is included in the Autodesk Collaboration v9 for Revit 2016 add-on, which can be downloaded from https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-coll....
Tony Michniewicz
Revit Software QA Analyst
Nachricht 4 von 5
sureshchotrani
als Antwort auf: Tony_Michniewicz
@Tony_Michniewicz
Does V9 Update for C4R take cares all other updates for Revit 2016, or we still need to install Update 7?
Nachricht 5 von 5
Tony_Michniewicz
Installation of Revit 2016 R2 Update 7 is not necessary because the Collaboration v9 installer combines several updates, including Revit 2016 R2 and Revit 2016 R2 Update 8.  Also, Revit update are historical so Update 8 includes all of the fixes that were included in the previous 7 updates.
Tony Michniewicz
