Pads don't show the cutting pattern underneath them
eduardo.schoenau
Message 1 of 33
eduardo.schoenau
I want to see the fill cut pattern underneath the pad, but when the cut plan goes under the topography region, only a white fill appears
Accepted solutions (3)
Replies (32)
Message 21 of 33
eduardo.schoenau
Unfortunaly, that's the only solution i founded.
In Brazil we call it "gambiarra".
Message 22 of 33
LMAO! I can't believe that's the solution here.
I learned that one back in kindergarten.  Then, we cut up colored crepe paper to create "filled regions".   That's the "old school" way - before Revit. 😉
Message 23 of 33
If you want the topo to behave like you expect from a solid element, then you could convert it to a floor with modified subelements using Dynamo.
Message 24 of 33
A floor would behave no differently. There's NOTHING there to show.
Message 25 of 33
eduardo.schoenau
but when you create an Pad, also create an Topo underneath, and that should behave like the others Topo around, or not?
(that's the real problem, if you notice in the image from the topic, the Topo from the Pad behave well when the cut plan passes right in the heigh level of the primary Topo)
Message 26 of 33
eduardo.schoenau
  i must be getting crazy
Message 27 of 33
Message 28 of 33
This is what your View Range is capturing:
This is what your are trying to show in the View:
Get it?
Note: Floor element used in lieu of Toposurface for this exhibit.
Message 29 of 33
eduardo.schoenau
@barthbradley , that's what i'm talking about. (look the @ToanDN image)
Message 30 of 33
eduardo.schoenau
This probably happen because the topography created by the Pad can't create an solid if doesn't appear in the view, and the solution isn't easy...
Message 31 of 33
RDAOU
I would split the topo as shown below and adjust each level's view Range to capture Levels below and 1x level above
Message 32 of 33
eduardo.schoenau
Great man, thanks!!!
Message 33 of 33
RDAOU
@eduardo.schoenau
Here is your revised file back...should you want to open and check setup... added plan regions to show different cut level for the blocks on each level
