Pads don't show the cutting pattern underneath them
eduardo.schoenau
Message 1 of 33
eduardo.schoenau
I want to see the fill cut pattern underneath the pad, but when the cut plan goes under the topography region, only a white fill appears
Accepted solutions (3)
Replies (32)
Message 2 of 33
Cut the Toposurface with a 3D Section Box.
Message 3 of 33
Lower the view range bottom and depth to capture the lower pads.
Message 4 of 33
eduardo.schoenau
sorry, you asking an image of this 3D section box?
there supose to be an filled underneath the pad, and seems to be only an empty space.
The point is, how i can show it in the floor plan?
Message 5 of 33
I thought you were trying to view your Topo from underneath in 3D View. If you are talking about Plan View, lower the View Range Depth/Bottom.
Message 6 of 33
eduardo.schoenau
thanks, but didn't work
Message 7 of 33
eduardo.schoenau
this is the only solution i'll have found, but i'm not suppose to define the view range based on that (plan region doesn't work too)
Message 8 of 33
View Range doesn't capture them?  Strange. Post your file.
Message 9 of 33
I'm confused. You are not supposed to define the View Range to capture the Pads, but the View is supposed to show the Pads?
Message 10 of 33
eduardo.schoenau
that's another file, with the same problem, the view name is "terreno"
Message 11 of 33
eduardo.schoenau
it's supposed to show the ground underneath the pads, not the pad itself
Message 12 of 33
Is the "Ground" outside the View Range?
...by the way, you can turn off PADS through VGOs if you don't want them shown - but you still need to adjust the View Range to see the infill bottom in the View.
Message 13 of 33
Message 14 of 33
Message 15 of 33
eduardo.schoenau
thanks @barthbradley for the patience, believe me, i'm trying my best here 😬.
take this other example, i have 3 pad's, for three buildings, in differente levels,
look the level 1, i'm seeing the empty space underneath the other pad's,
but i want the cut plane passes by 1,2m from level 1, because that how the view works.
Message 16 of 33
RDAOU
Message 17 of 33
eduardo.schoenau
Message 18 of 33
I'm not following. Everything is visible if it's within the View Range.
...a View will not show something that is outside of the View Range.  That's a good thing.  Otherwise, our Plans for a multilevel building would look like sh*t.  Know what I mean?  I you need a Plan that locates Building Pad Cuts. then you create a View with a View Range that will capture the cuts.
Message 19 of 33
I think you need to place a filled region with the same color/pattern as the material to fix the view.
Message 20 of 33
eduardo.schoenau
ok, but the floor plan for level 1 and 2 doesn't show the right representation, look that now i put a door in each building.
I'm not supose to change the cut plane, it must cut in by 1,2m.
Only if i change the whole cut plane and make an plan region, but i don't think that's a logical workflow.
