Override the spatial container
ESS-ibenhassen
ESS-ibenhassen
HI Revit users,
   It is possible to override the spatial container of an element by adding an instance parameter IfcSpatialContainer ?
How we can do that?!!!
Thank you for your answers or/and help!!!
se.ha
Hi @ESS-ibenhassen,
just follow these steps to create a project parameter (instance) named "IfcSpatialContainer" and select all the necessary categories:
Create Project Parameters | Revit 2019 | Autodesk Knowledge Network
Now you can enter the name of the level you want the element(s) assigned to. Please note that the level must be checked for export as Building Story.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
ESS-ibenhassen
Thank you for your answer.
I made a mistake, my question is about "IfcSpatialZone", if you can help ?
