Override Parts?
7 REPLIES 7
Message 1 of 8
Sahay_R
631 Views, 7 Replies
Override Parts?
Is it just my imagination or can we really not override the graphics of wall Parts? I've tried everything - Object Styles, VG, Filters, right click and override graphics per object - can't for the life of me get a black line to go around the parts. Do I really REALLY have to use the Linework tool for this?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
7 REPLIES 7
Message 2 of 8
in reply to: Sahay_R
Show Both under Parts Visibility in View Properties.
...if need be, set Wall Category Detail Level to Coarse under VGOs.
BTW: Hi. 😉
Message 3 of 8
Sahay_R
in reply to: barthbradley
'Both' does things I don't want - brings back the pink poche which we REALLY do not want to see on the detail view and also does weird things to the sketch edit that has been made.
Rina Sahay
Message 4 of 8
Pink Poche from Coarse Fill?  Can't you Override that? Under VGOs.  Cut Pattern off.
...is this the look you are going for?
Message 5 of 8
Sahay_R
The pink is gone - however the sketch turns weird.
This is what I want -
VS this is what I get when I see BOTH -
Rina Sahay
Message 6 of 8
Ah! I see.  Linework Tool...maybe?  Probably not.  Hmm?
Message 7 of 8
You can get there with LW Tool and Dividing Part at Wall end.
Message 8 of 8
Sahay_R
Yep. Been there done that. Just thought there may be a more elegant solution.....
Thank you! Good to hear from you after such a long time!!!
Rina Sahay
