Orientation for Symbol of Spot Elevation - Target Filled
BIMAbhi
BIMAbhi
We have found an issue when we change Spot Elevation tag into Revit. We have attached a snap for easy reference.
Please help!
Thanks & Regards
BIMAbhi
JacobDSimpson
Hi there,
Can you not go in to the family and remove the areas? Or edit in the properties area? Is it the angled arrow you are trying to get rid of?
BIMAbhi
Thanks for your comments.
Mainly we want to place the tag with same orientation [2 nos of solid hatch in the tag circle] when dragging the tag up/down or left /right condition.
Please let us know if you need nay further clarification regarding the same.
Thanks & Regards
BIMAbhi
JacobDSimpson
Ok, try going in to the family and rotating the 2 black areas 180degrees, then you should be able to get the tags on either end to be in the same corners. Just use two different tags.
JacobDSimpson
You could always change your spot elevations to exterior filled arrows? These display the same whether your arrows are left or right sided.
BIMAbhi
Can we change this for i the "circular tag with two hatch" family which have shown in my queries snap?
Thanks & Regards
BIMAbhi
