Can't Modify a wall thickness
2 ANTWORTEN 2
Nachricht 1 von 3
2254 Aufrufe, 2 Antworten
Hello, I've tried times and times to make a custom wall by clicking on an edit type of an specify wall and then click on duplicate and write any name then click on edit, and type the the thickness I want, and it all goes wrong with a screen display in attachments, Thanks in advance.
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: Anonymous
Looking at the screenshot I think your system is setup to work in millimeters. So you ask Revit to create a wall with a thickness of 0.3 mm.
Revit's minimum length value lays around 0.8 mm.
So try to enter a more realistic wall thickness like 100 or 200 mm.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
als Antwort auf: L.Maas
Actually I did modify the units before (meters), and I went to check this out again then modify the thickness and yes it works, thanks a lot :leicht_lächelndes_Gesicht:
