Hi There,
I am wondering if I can redownload the trial version I installed two days ago. There are several issues that I can't attribute to operator disfunction. There are no components, but most of the other issues are visibility issues - some walls and ceilings don't appear in various views even when they are in the view range and on the same plane as other walls, can't change line types - e.g. green to black, some objects are greyed out so I can't click them on and hide them in views, etc. Also the phasing filters simply don't work - I can't get existing walls to grey-out or be half tone, and demo doors sometimes cut out the wall sometimes the walls remain in the demolished door cut. I just don't know how to troubleshoot and am not sure what to look for in the program file. My operating system in 64-bit X64-based processor.
Any advice? Thank you!
yes you still can download the software as long as you have your serial number, in your issues in revit have you check if there is a view template assign in that views and try to set to none and see if helps. thanks
Autodesk made a decision (not well advised in my opinion) to not include content in the 2021 installation. Download and install the content here - https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
the other way is to share the file so we can check and you can try to refer to this link and see if helps. thanks
