Opening placement Options
Message 1 of 9
I would like to know where could I please find the opening placement options that appeared in the picture.
Replies (8)
Message 2 of 9
planner_matlabi
Hi
Please explain more about what you are doing?
and
Which Revit Version?
This is related to the old version
Message 3 of 9
Sahay_R
Hi @Anonymous - look in the Architecture tab>>Opening group
(mine is greyed out because I am not in a view - if you are in a view all these options will be active)
However, I don't see the options from your screenshot. Hopefully, this does what you want it to.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 9
I am trying to create a dormer in a mansard roof with double slope but apparently it is not possible to get it due to the two different planes that conform the roof.
Message 5 of 9
cbcarch
You could also use an in-place Void to Cut Geometry for the roof(s).
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 6 of 9
planner_matlabi
Watch Screen cast
Message 7 of 9
I don't have any problem create a roof dormer over a mansard roof.  See attached Revit 2017 file.
Message 8 of 9
bimscape
I'm guessing the difference is that you  (@ToanDN) created your roof by extrusion- so it's one roof- which the Dormer tool likes, and the OP created Mansard as 2 roofs- one on top of another (both by footprint)- lower one using a Cutoff Level- so the Dormer tool is grumbling about the two roofs?
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Message 9 of 9
Viveka_CD
Hi @Anonymous
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thanks!
