Opening a revit file in autocad?
dmcnabb
dmcnabb
Can you open a revit file into autocad. if so does the autocad version need to be the same or newer version that Revit is
No. Revit must export to DWG first.
Jeff Hanson
Autodesk - AEC Technical Publications
Manchester, NH
wrote in message news:5950093@discussion.autodesk.com...
no... it needs to be exported from within Revit.
Melanie Perry
***not all who wander are lost***
http://Tech-Tea.com
http://MistressOfTheDorkness.blogspot.com
Can you export a dwg from Revit for me, Oh Great Mistress of the Dark, I mean Dork?
shiny.stephen
No it’s not directly possible. You will need to export the rvt file to a dwg. More details can be found at the below link:
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/1394-Document1394/2112-Print_Ex2...
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Shiny Stephen
Support Specialist
Product Support
Autodesk, Inc.
davnon
Community Visitor
Community Visitor
Such an answer can not be noted as helpful
