Saving an rte to rvt...
Message 1 of 9
I have set up my template file (rte). When I open that file and try to "save as" an rvt file I do not get that option. Is there another way to do this?
Replies (8)
Message 2 of 9
Create a new project using this RTE. Don't do anything in it. Save the
project. Bingo! RTE to RVT.
Jeff Hanson
Autodesk - AEC Technical Publications
Manchester, NH
wrote in message news:5981602@discussion.autodesk.com...
Message 3 of 9
Thanks, that did it
Message 4 of 9
Is there a way to save it to a .rvt after you have completed your design?
Message 5 of 9
loboarch
I am not sure I understand the question? If you drew a whole project and saved as an RTE, you can do the same thing i described above. Create a "new" project using this RTE and then just click "save as" and choose project. Now you will have an RVT file.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 6 of 9
sshim4CJX2
Observer
Observer
While saving rte to rvt, at save as, project is white out.
Is there any way to save to rvt file?
Simon Shim
Message 7 of 9
Simon Shim
Just create a new project using the RTE as the template then save that project.  There you are a RVT file.
Message 8 of 9
sshim4CJX2
Observer
Observer
I did, opened a template file rte and imported .exr file and tried to saved as a project file.
but it is white out.
What could be wrong?
Message 9 of 9
Do not open the RTE.  Please read the previous post carefully.
