open multiple files revit 2016
I have the Revit Architecture 2016 and my problem is that every time I double click on a file opens it in separate files But I consume me much memory and machine load much anyone can help me with this problem? It would appreciate enough .
L.Maas
Just use the open function in Revit or drag the file onto your already open Revit session.
Louis
Please mention Revit version, especially when uploading Revit files.
that way if I work but I need to do it from the eplorador windows and every time I open a draft creates another instance revit me ( I started twice revit ) and makes my pc being too slow
RDAOU
@Anonymous
If you insist on using Explorer; DO NOT use double click
1... Either select the file and hit ENTER
2...OR select file; left click and select open
DOUBLE CLICK is bad practice/habit not just for Revit 🙂
that way if it works but if I start projects from the scanned I still begin revit many instances there is some property that can change?
Firstly, I cannot understand what "start projects from the scanned" means?
Secondly, why do you insist to open Revit files using doubleclick from a Explorer window?
RevitBuilder43
For convenience, you can use add-ons such as tab coloring to distinguish open documents from each other.
For example, to COLOR YOUR TABS or change the POSITION OF WINDOWS (cascading / mosaic).
I attach to the video the coloring of the tabs by belonging to the open projects of Autodesk Revit.
Video on YouTube:   https://youtu.be/b0PXfTu7xyw
Cascade/Mosaic
Colorizing Tabs In Autodesk Revit
Theme In Autodesk Revit
