Filled Regions not printing filled
4 REPLIES 4
1846 Views, 4 Replies
Hello everyone,
I am a long-time Revit user, but have come across an issue which I can't figure out. It involves printing 2D elements (blah!)
Using Revit 2015
  Update Release 9
  20150704_0715(x64)
Printing with
  PDF X-Change Printer 2012
  5.5 Build 313.1
  Windows 7 Pro x34 (Build 7601: Service Pack 1)
I have a host file.
In my host file I have a wall-hosted recess.
In my wall-hosted recess family, I have a filled regions.
When I print a PDF file of just the host file, the filled regions print...filled.
(See GOOD.png)
I have a linked revit file.
When I print the same view with detail elements turned on in the linked file, all print regions disappear.
Including the wall-hosted recess family which lives in the host file.
(See NOT_GOOD.png)
Has anyone had this problem?
Does anyone have a solution?
Maybe it has something to do with my PDF Driver?
4 REPLIES 4
angelica.rodriguez.3d
Try printing using raster processing. For some reason filled regions and elements in grey sometimes don't show properly in vector.
Let us know if it works.
RDAOU
@Anonymous
It is a PDF driver issue as I have seen this occur on one station with one driver and the same file on another station with a different PDF converter seemed to work fine. Similar to the issue with non rectangular/segmental filled regions; on some PDF converters work fine and on others not. It seems to have something to do with the way some of those drivers communicate with Revit and how they interpret/prioritize the placement order of elements in a file/model.
It could be other reasons too but I know that the following work for some...maybe it works for you too
Possible solutions:
  1. Are the common edges of the filled regions locked to the edges of the walls/recesses (if not try to align&lock) and try to print again.
  2. If they are locked already; select and on the Modify|Detail item >> Bring to Front then try print again
  3. Try to print from a station with a different configuration/driver
in reply to: angelica.rodriguez.3d
Sorry Angelica, but vector PDFs are a necessity. The zoomed image quality is just not good enough with raster printing.
(File-Size is also much better with PDF, packages can still be e-mailed.)
in reply to: RDAOU
Ay U,
I will have to try printing from another station.
Everything else has already been tried. (When something doesn't work, I fiddle with it until I can't get it to. That's what brought me to you. ,)
I downloaded a trial version of Adobe Acrobat Pro, but it didn't work.
Cheers,
Matt
Forma Design Contest
