Open an .fbx file with Revit
Hello there,
I have received two .fbx files and I would like to work with Revit on this project.
I have already opened these files on Naviswork and tried to export them somehow, but I haven't been able to open the  existing model with Revit.
If anyone could help me with the workflow to get there I will really appreciate it!
Thanks a million 🙂
1. Import FBX in AUtoCAD and save as DWG.  Then link or import DWG in Revit.
2. Open FBX in Navisworks and save as NWD.  Then insert NWD in Revit as a coordination model.
Either way, don't expect to be able to edit it in Revit.
THANK YOU SO MUCH!
I also got the files in .obj, .mtl, .max.
Would you know any way to get an editable drawing on Revit?
Thanks again 🙂
