reveals and exterior finishes
arkitek2ss
arkitek2ss
is it possible to add a reveal (EIFS) so that the inside faces of the reveal is black and not the color of the EIFS without using the paint tool?
Howard
If you Create Parts and set the View to Show Parts then the reveal will show with the material of the inner layer if it is exposed.  You can also manually change any materials of Parts to be different from the originals.
arkitek2ss
will try that.   have not used 'Parts'.
thanks.
Interesting inquiry. I pondered several ways you could do it (and @ToanDN points out a very smart way), but I really think the easiest, and most practical way do it is through Paint.
arkitek2ss
but if you have 10+ reveals to paint the inside of the EIFS black (so that in a rendering, it pops a little more).  Its not necessarily the back of the reveal but the side face of the reveal.
Add a wall sweep at the same location of the wall reveal , with a profile to match.
