Solved by aRcHiTeCt.JM. Go to Solution.
Solved by AutoCAT95. Go to Solution.
… hi @Anonymous
… nope…. not without installation
… my recommendation is that you need to ask the designer to send you all plans and layouts in .pdf
… or in …any kind of images or documents
… and “if” you are able to install it
…. I don’t think you will be able to use it
… if you never work with this … it’s kind of complicated
... or as @AutoCAT95 said try with that autodesk 360 ...
... but it will only show you the last 3d view of the project when saved
... as I understand you can not go back and forth from plan to view
... and so on.... so it is super restricted
... also it wil be missing all linked files
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
I don't understand about the Revit , I'll be asking to the people designing the office to show us in any other kind of presentation. Anyway Thanks.
