Can automatic door opening be disabled?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
dburdwood.ca3
581 Aufrufe, 6 Antworten
I am currently working on an existing conditions model for a client, and i have an arched masonry opening for my garage. The existing garage door is not an arched door, and the door just falls behind the arched opening on the inside of the garage wall.
When i place the garage door however, it overrides the wall profile that i have created and makes it to whatever opening the doors needs. Is there anyway that I can override the opening that the door family creates and just leave the wall profile that i had created?
I have attached images for reference, Image 1 is the existing opening profile and image 2 is after i place the garage door.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: dburdwood.ca3
Yep, build an unhosted family.
Else, modify the garage door family to have the archway instead of the standard rectangle.
Nachricht 3 von 7
@dburdwood.ca3
You could just edit the door family and delete the Opening Cut.  Everything else stays the same.
Nachricht 4 von 7
dburdwood.ca3
als Antwort auf: ToanDN
I did try this, but since it is a wall hosted entity it will not allow me to delete the wall from the family, which is still overiding my wall opening.
Nachricht 5 von 7
@dburdwood.ca3
I didn't ask you to delete the wall, only the Opening Cut.
Nachricht 6 von 7
Modify the  Garage Door so that there will be an archway.
Nachricht 7 von 7
Yes, you can do so by modifying the Garage Door. Thus, you will get an archway.
