Old Project Parameter connected to Family
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
See attached image.
With our last revit template we added a "Waste Factor" project parameter so that in the schedules and materials we could add a number....
With our new template we removed this parameter as we no longer needed it and it seems that the Project parameter has somehow linked into the individual families.
When you start a new project there is no "Waste Factor" project parameter, then you insert a door into the project and the "Waste Factor" parameter appears under other as an instance and appears in the Project parameters list. You open the door family and the Waste Factor parameter doesnt exist anywhere.
The more categories of families you insert into the new project the more Waste Factor project parameters appear in the list we've had over 10 appear once a project is done. How do we remove this parameter from a project when it doesnt exist? At least not in a way we can find.
