Are both Revit and Formit capable of modeling building like Zaha Hadid .If not then what other software can be used?
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Depends a lot on the skills of the users. Do a search for modeling freeform in Revit using conceptual massing, adaptive components, and maybe Dynamo.
... yes , you can design something like this with REVIT
.... with the conceptual mass
... it is going to be a hard job
.... but eventually you will get there
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
@Anonymous wrote:.If not then what other software can be used?
... 3dsmax
... rhino
... sketchup
aRcHiTeCt.JM
REVIT EXPERT ELITE
