Offset with the option to automatically delete the original item
Jeane_DuPreez
Message 1 of 8
Jeane_DuPreez
The idea is, when you offset something, you have the option (a tick box) to automatically delete the original object you're offsetting.
For example. in sketch I want to offset a sketched box 25 mm smaller, instead of offsetting and then deleting all original lines, they will be automatically deleted.
Replies (7)
Message 2 of 8
kimberly_fuhrman-jones
Hi, @Jeane_DuPreez ,
Is this the functionality you are requesting? If so, it already exists in Revit in the Options Bar of the Offset command. Unchecking this box will offset the object without creating a second object.
Kimberly Fuhrman-Jones
Revit Community Manager
Message 3 of 8
Jeane_DuPreez
Hi Kimberly, my apologies I should have added that this feature would be nice in Revit, I believe it's not available in Revit.
Message 4 of 8
@Jeane_DuPreez , what I show is in Revit...2024 Dark Theme. 😊 But the feature is available in all versions of Revit.
Message 5 of 8
SteveKStafford
Like Kimberly wrote...glance at the options bar while the Offset tool is active, uncheck Copy. Similar for Mirror.
Steve Stafford
Message 6 of 8
Jeane_DuPreez
Oh, I see, I feel like such a fool. Thank you.
Message 7 of 8
Jeane_DuPreez
Thank you, I should have paid more attention.
Message 8 of 8
SteveKStafford
No need to feel that way, not the first nor the last to overlook subtlety, Revit has plenty to go around. 🙂
Steve Stafford
