Numbering sequence in Schedule
achusetiawan
Message 1 of 9
achusetiawan
I currently have a problem with numbering on the schedule. Because I'm currently making a manual, so when I add a line or delete a line, I have to retype it. Does anyone have the same problem and the solution Thanks.I currently have a problem with numbering on the schedule. Because I'm currently making a manual, so when I add a line or delete a line, I have to retype it. Does anyone have the same problem and the solution Thanks.I currently have a problem with numbering on the schedule.
Thanks.
Replies (8)
Message 2 of 9
ennujozlagam
you can refer to autodesk apps store .and see if helps
Message 3 of 9
Need some more information to troubleshoot.  Like to see the Schedule setup. Can you post it?
Message 4 of 9
achusetiawan
I will try with this application, if indeed there is no credit from revitnya,
Thank you for helping
Message 5 of 9
Khadourwaseem
I've actually found a way online, You can check it right here
https://www.youtube.com/watch?v=H1Z3f1pgyPE
Message 6 of 9
batbilegbt1
Community Visitor
Community Visitor
is there any solution here?
Message 7 of 9
Solution to what problem?
Message 8 of 9
batbilegbt1
Community Visitor
Community Visitor
i manually number the parts highlighted in red, it takes a lot of time so maybe is there any tool to automatically number this section?
Message 9 of 9
PyRevit renumbering tool.
