Nothing appears in Camera View Render
I have a problem, I am not able to sovle out. When I render any camera view, the only thing that is rendered is the sky. I have tried interior and exterior render, changing sun setting and so on. I have this problem only with all camera views. 3D view render is working fine. Also in camera view realistic and Ray preview work fine. I really dont understand what might be wrong. Can you help me please?
Thank you, Lucie
constantin.stroescu
Which version of Revit do you use?
If 2016 , you render with Nvidia Mental Ray or Autodesk Raytracer?
Or you use another renderer? ( maybe in Autodesk Cloud or an addin renderer)
Constantin Stroescu
constantin.stroescu
Something like that depicted by you could be if rendering in Nvidia Mental Ray with seting Haze to a maximum, as can be seen in my screenshots:
Constantin Stroescu
I am using revit 2016. Haze is not a problem. Both renderes are doing the same. They render only sky and grey floor, same as in your first image, accept there aro no objects. Ofcourse i tried render it in cloud and it is doing again the same. Just empty space. I am using revit for many years and this is realy mistery for me. Nothing like that has ever happened to me. When i copy model into a new file it is working fine. But its a problem for me, because I have many view in the not working one i just cant copy. Or it would be a lot of work.
What was your solution?
I am experiencing those same problems and I am desperate.
I attached a screenshot with the model to render. and another screenshot with the result of rendering. As you can see, everything is transparent except some pillars and a window.
RDAOU
Which Revir version/build are you using? Do u have all patch updates installed?
It is rendering something it seems just some missing items...
1. Does it happen (this partial render) on all views? Or particular ones?
2. Did u try to clear the windows temp folder
3. Are there any odd families  which you may have downloaded from somewhere (some imported wall/floor families which are originally not native revit families can  cause this when captured in the view being rendered
Ps. Do consider starting a new thread with your topic
