Note tag
Note tag
ShifraSpiegel
Message 1 of 9
Note tag
ShifraSpiegel
What would be the best way to change this multileader tag to a spline instead of a line? Is there a way to create the the spline with 2 adjustable points?
Accepted solutions (4)
Replies (8)
Message 2 of 9
ShifraSpiegel
Ive attached a picture here
Message 3 of 9
You can't.
Message 4 of 9
ShifraSpiegel
Is there anyway to create the multileader spline separate without the text?
Message 5 of 9
vitorbortoncello
Revit's annotation tools are primarily designed for precision and control. However, you can achieve a similar effect by using a Detail Line, but personally i don't think it is very helpful to do so
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 6 of 9
Are you looking for a workaround or a standard?  In other words, are you wanting to do this selectively and limitedly, or everywhere and all-the-time?   I mean, you can turn off Leader Lines and draw Splines in their place, but this isn't a practice I'd standardize.
Message 7 of 9
ShifraSpiegel
How do you turn off just the leader lines?
Message 8 of 9
ShifraSpiegel
How do you turn of just the leader lines?
Message 9 of 9
