NOTE BLOCK
NOTE BLOCK
Message 1 of 15
NOTE BLOCK
I'm making a note block and when creating the text label I am unable to snap to anything? I can eyeball it and get it close, but seems like using snap would be a lot easier and more percise.
Jeff
Replies (14)
Message 2 of 15
dzanta
2d annotation text does not have properties such as reference planes, lines, snap points, etc.
3d model text does
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 15
Would be nice if 2d text had snaps. My eyeball is pretty good, but It would be better to able to use a snap point.
Jeff
Message 4 of 15
Note block is definitely what I want and I watched some tutorials on creating them, but I'm have a problem adding rows. See the attached jpeg's.
Jpeg 1 - shows the note block on the sheet and it looks correct with how I want it to look.
Jpeg 2 - has the title selected and I can add row here
Jpeg 3 - has the note content selected, but the add row is grayed out.
I have looked all over and cannot find answer to this. What is the A & B columns, they dont show when out of edit mode?
Jeff
Message 5 of 15
I figured it out. I had to add the symbols to the revit view first....duh. Sorry. Atleast I'm figuring it out lol.
Jeff
Message 6 of 15
Okay I have one more question on note blocks. If I want to use the same note block on multiple sheets, but all the notes do not appear on all sheets. I was thinking of two ways of handling this.
1) to add a note to the note block that says something like "All notes may not appear on this sheet"
2) or maybe if possible would be to have a override for notes that dont appear on sheet and add text ommited or not used.
3) create separate note block for each sheet but this seems like a lot of work and probably not a good idea.
anyone have suggestions?
Jeff
Message 7 of 15
cbcarch
You should be able to create duplicate Key Note Schedules and place on multiple sheets.
FWIW---in the future you should consider Keynotes. This is where "true keynoting" is a better approach than Note Blocks. You can create Keynote Schedule and set to By Project or By Sheet.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 8 of 15
I see what you mean about creating a duplicate, but It want a unique name. I want it to just say construction notes on all sheets. See attached Jpeg for an example. In the jpeg I changed notes 15 and 24 to omitted, but now iI'm stuck with construction note copy 1. Anyway to do this? I will be checking out keynote schedules, but for now I'm going to use the note block.
Jeff
Message 9 of 15
cbcarch
I believe you can set up sheet parameters and assign them to the annotation symbol family, then filter the schedule by sheet name / number?
(Again, Keynotes, Keynote Text File and Keynote Legends are a better approach IMO.)
Cliff B. Collins
Message 10 of 15
Be careful when you changing some notes to Omit on the copied schedule because it would change on both.  Both schedules reference the same symbols and their fields.
If you want to use Note Blocks, you better be okay with a master schedule with an umbrella note saying 'not all notes are applicable' or such.  If you go with true Keynotes, you can opt to have a per Project schedule which is smilar to above, or per Sheet schedule, which is still one schedule but it only picks up the keynotes placed on the target Sheet.  If you are familiar with Revisions setting, they are pretty much the same.  As Cliff has pointed out, it may be a better option for you.
Message 11 of 15
If keynotes blocks are better why does revit have note blocks?
Jeff
Message 12 of 15
Keynotes need to tag to actual objects: model entities or detail components.  Note blocks do not.  They are just generic annotation symbol you can place anywhere.
Message 13 of 15
I'm now exploring keynotes and made a custom text file and it is all working well, but I need a couple of the keynotes to have multiple leaders and I don't see this option? In the note block it had the option. Is there a leader command?
Jeff
Message 14 of 15
No. Keynote tags a single object, very much like any other tags such as door's or windows. That's why it can only have a single leader. You can either fake it in by add leaders to a blank annotation family, or put several of the same keynote on top of each others.
Message 15 of 15
I guess that is one to add to wish list.
