Not visible in view
Not visible in view
richard_pineda
Not visible in view
richard_pineda
I'm using phasing want to add walls, doors etc, said the is not visible in the view. Any suggestion to help me.
Accepted solutions (3)
it's one of these 33 reasons -- I guarantee it.
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Are you add them under a Demolition plan? Don't do that. Open an existing view (phase status = existing, phase filter = show all) to add existing elements.
_Vijay
Try to change phase Filter from view.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Mohamed-Nassar
check the phase u draw at it before model
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
RobDraw
Read the entire message. It also gives you a list of reasons why. You should check those.
Rob
ennujozlagam
You can try this, create a view template in the same view/phasing that you are able to see your walls, door,.. etc. > then apply that view template you created, in the view you want to create a wall, door.. etc. and later set to none after you've done and see if helps. Thanks
