NOT THE SAME ELEMENT ID
Cyril_Osano
Cyril_Osano
I’d like to ask about a  issue I’m encountering.
When exporting a NWC file for my project, I’m noticing that the Element IDs for tree planting differ between the NWC and RVT models. However our elements are correct thou.
See the snap below.
vitorbortoncello
The Revit Element ID is an integer that uniquely identifies an element within a single Revit project but not across multiple models.
See more about it below:
https://www.modelical.com/en/how-are-elements-inter-coded-in-bim-bim/#:~:text=Revit%20Element%20Id%3....
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
handjonathan
Hi @Cyril_Osano
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
