For the final floor of my project it is not allowing me to select the walls and move them over. I want to be able to grab the whole floor and move it over because it is off by a little bit but it is not letting me. Also the floor is more faded then others. I attached my project below if someone could help I would appreciate it.
Solved by ennujozlagam. Go to Solution.
@Anonymous hello, in addition i already adjust your elevation view, added floors, levels, view range...etc...etc. use the file attached. thanks
Dude.
Didn't I JUST teach you this a couple of days ago?
9. In either case...
10. Put all the View Range settings for the Level 4 plan view back to the default values instead of the crazy values you've got in there now.
11. Learn from this, so you don't have to come back tomorrow and ask how to move something from Level 4 up to Level 5.
In the other thread, remember? See #10? You didn't do that. See #11? You didn't do that either.
