No top rail or handrail type parameters
Reed_Weinstock
Reed_Weinstock
Is there a setting that enables some rails to not have top rail and handrail types options?
Top Rails and Handrails are defined the Type Properties of the Railing.
Create a Rail Type without Top Rail/Handrails if you need 'em.
Reed_Weinstock
I understand that. I am asking why those parameters are not visible in the type properties dialog in the image i posted.
What version of Revit are you using?
Reed_Weinstock
21. I can those parameters in another rail family but not this one for some reason.
Sounds like you are using a Rail Type that was created in a version before Top Rails existed.
Open this railing sample file and you'll see the same thing.
Revit Sample Stair and Railing Files | Revit 2019 | Autodesk Knowledge Network
