No rendering showing
When I try to render an exterior view with sun only It is getting all black. I can just barely see the image in the background (image at the back), but it is way too dark. I have moved the sun.
I am just clicking rendering in a 3d view, do I have to do anything else? Thanks.
aRcHiTeCt.JM
…. hi @Anonymous
… based on what you are describing (and the picture)
… my guess is that it is something to do with adjusting the exposure
…. try this:
… in the rendering setup
….click adjust exposure
…. and tweak exposure value
… or maybe you are inside of a wall or family or a tree or a bush?
… for this you will need to move your camera couple of inches to the side / front
…. or …  if neither of the above are working for you
… can you upload your .rvt to take a look?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
I didn’t know that.
It was the exposure value and the shadows.
Nothing is in the front because the picture is taken from a very high point.
Very good.
