Hi Everybody,
I've been having an issue with applying dynamo scripts to a project.
The Dynamo-script is an adjusted version of the "Element View Generation" script that can be found online. The adjustments were made so that I could choose to add cross views and/or front and/or side views and the script only wokrs on columns. The script works fine and generates the views, the problem however is that as soon as I apply the script to a column, a blue outline appears around the column on all my views. This outline persists even if I turn off all model and annotation categories. If I print a plan the blue outline is printed as well.
No settings were changed in the view templates or overrides. The blue outline seems to be drawn independently from the column, since if I move the column the outline does not move with it put stays in its original place.
I have no idea what causes this outline and would greatly appreciate any help or insight into this problem.
I have added some screenshots of the outlines.
Best regards,
Luis
EDIT: The Solution to the problem was to turn off Revit background preview in Dynamo. I tried this solution before but it didn't change anything. After restarting the model the blue outlines were however gone. I'll leave this up in case somebody else has a similar problem.
