No keynote data path
Hello, don't find kaynote data. Autodesk say what is down explosed above.
How can I found the path?
Thank's
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2019/...
Use the following procedure to resolve the issue.
To specify the location of the keynote text file
  1. Click Annotate tab
    Tag panel
    Keynote drop-down
     (Keynoting Settings).
  2. In the Keynoting Settings dialog, click Browse, and navigate to the appropriate keynote text file.
  1.
RDAOU
try this path C:\ProgramData\Autodesk\RVT 2020\Libraries\US Metric\RevitKeynotes_Metric.txt
if you need the Italian version go to C:\ProgramData\Autodesk\RVT 2020\Libraries\ then navigate to the Italian folder
@RDAOU thank's.
1) For the two paramethers below which have to select? (Absolute and bykeynote)?
2) An other info: if paste the path you write  C:\ProgramData\Autodesk\RVT 2020\Libraries in a pc folder I found a path.
If try to search to myself from C:\ I don't find Programdata. There are Program Files and Program (x86).
Can is be that the fornder is hidden?
xx
RDAOU
@Anonymous
It is a Hidden folder
Which to use absolute/relative/at library location depends which keynote file you want to use and where you have placed it...considering that you can also create your own keynote .txt files
For now use the path I gave you / at Libraries Location
  • Absolute: Identifies a specific folder located on your local PC or a network server. The path format looks as follows \\servername\share\folder\keynote.txt
  • Relative: Finds the keynote file where the project file is saved. If you move the file to another location, Revit expects to find the keynote file in this new folder location as well.
  • At Library Locations: Finds the keynote file where the stand-alone library is installed. Meaning the path to Revit 2020 libraries which I have just given you earlier.
