No Grid in Ceiling Plan
Message 1 of 11
So I've had this problem for a while but each time I go into the ceiling plan there's no grid on the ceiling plan so I can put lights and other things on there I'm so confused and frustrated please help.
Autodesk Revit 2021.1.2 - [Small House - Reflected Ceiling Plan_ Level 1] 5_2_2021 4_04_07 AM.png
Replies (10)
Message 2 of 11
RDAOU
@Anonymous  go visibility graphics and make sure Ceiling category is checked visible ... then check that the view range settings and make sure the set rang is adequate to show the ceiling
Message 3 of 11
My ceilings are checked in visibility and graphics  and as for view rang is set to cut plain 7" 6" and off set 2" 0"
Message 4 of 11
Reveal Hidden Elements.
Message 5 of 11
no elements are hidden
Message 6 of 11
syman2000
Go to 3d and check and see if you able to see the ceiling. If there is ceiling, check the height offset from the level. Normally if you set ceiling offset to 0, it will be at the floor. If you don't see it, set the 3d phase to show none. Check if the ceiling is placed in wrong phase. Also if you have design option set, check and see if you placed the ceiling in different design option.
Message 7 of 11
RDAOU
@Anonymous
Did you assign any material to it?
Message 8 of 11
Did you actually create a Ceiling?  One with a Surface Pattern?  On the same Level you are Viewing?
Here's a cheat sheet you can use to find "stuff":
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
Message 9 of 11
Here's the project if anyone can figure it out I appreciate it
Message 10 of 11
syman2000
When I set to unlimited, it will show up.
Message 11 of 11
omg thank you
