New to REVIT, Using MacBook F Keys and Track Pad
tahlula999
tahlula999
Hi There, I am taking REVIT and Auto Cad remotely and sign in to a Remote Desktop to access both REVIT and CAD 2020. I assume the remote programs are PC based. I am using a new MacBook Pro to complete these courses. I am having difficulty using the track pad on the MacBook to pan and zoom. I am also given short cut FKeys in the curriculum to use. My question is, are there any options when using the Track Pad that may make my life easier or am I better off purchasing an Apple Magic Mouse. Will there still be issues using the Magic Mouse.  for the FKeys are there any short cut key specific to Mac ( I understand there may not be any thing that will help with this as I am not using the Mac version of the software)
Thanks for your help
Cheers
Erin
syman2000
I do recommend getting USB mouse with wheel. It will make your life easier. As for function key, I don't think Revit use it as much as AutoCAD. However if you want to learn Revit Shortcut, you can check this website
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/EN...
This site has good keyboard shortcut you can print and learn
https://www.scan2cad.com/wp-content/uploads/2020/10/Revit-Keyboard-Shortcuts.pdf
tahlula999
Hi @syman2000 thanks for your response. Will my Mac recognize a mouse with a roller ball, I was not sure if it would lol.   I will check out the links for some of the shortcuts.
thank you so much for your help
Cheers Erin
syman2000
Yes. Several of my colleague with Macbook did this when they remote into PC.
tahlula999
ok great thanks
