New Rooms
shahin_kiyomarsi
New Rooms
shahin_kiyomarsi
My old room layout is still showing when I try to put new Rooms. I completely deleted all the rooms. I went through all the linked files, theyre using Spaces not Rooms.
And there is no boundaries anywhere, why cant I place rooms to my new layout??
Replies (7)
Are walls in you model or from a link?
shahin_kiyomarsi
in my model
Maybe your View Range Cut Plane is too high.
@shahin_kiyomarsi wrote:
in my model
This happens when you floor plan view was not created using the correct Associated Level, but copied from a view of another level and changed View range.
Can you show View Range screenshot?
HVAC-Novice
Maybe a wall that is not visible in this plan view. For example a soffit. Create a section view and make rooms visible to see where it is "stuck".
Revit version: R2025.4
in my model
That's the solution?
I'm betting you checked Room Bounding in the Link Properties and that did it.
How'd I do?
