New level creation not seen in project navigator
jsWVQ7U
Message 1 of 10
jsWVQ7U
I created a new level in an elevation using Level (LL) and it shows in a vertical view, but it doesn't show up in the project navigator side window. Any help is welcomed. Thank you!
Accepted solutions (3)
Replies (9)
Message 2 of 10
vitorbortoncello
You need to create the view:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 10
RC_RVT
Make sure that the button to "Make Plan View" is ticked when you draw your new level.
Message 4 of 10
jsWVQ7U
Thank you much for your instruction!
However, I'm a beginner. Would you mind indicating where can I find that button "Make Plan View" please? Also, the version that AutoDesk downloaded is in Portuguese as I'm in Brazil. That causes more confusion because sometimes the terminology used in English is not a direct translation into Portuguese...
Message 5 of 10
RC_RVT
Hi @jsWVQ7U see below screenshot, I have put a red box around the tick box you need to tick.
Message 6 of 10
hubbardFJXGT
Also you have "Do not duplicate existing views" checked in your create plan views dialog. Uncheck that or choose/create a new view type.
Message 7 of 10
jsWVQ7U
Thank you much! This solution solved my problem! Thank you!
Message 8 of 10
jsWVQ7U
Thank you much indeed! It worked!
Message 9 of 10
jsWVQ7U
Thak you much indeed! It worked!
Message 10 of 10
jsWVQ7U
Thank you! It worked!
