Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board.
New at Revit- Wall command isn't working
keimigassociates
Message 1 of 8
keimigassociates
I have a floor plan that I laid out in AutoCAD and I'd like to try to model it in Revit.  I have saved the bare plan and linked it to my Revit file.  For some reason, when I try to draw my exterior walls I don't get a wall with the appropriate thickness, instead I just get a line and an error "Could not create integral wall sweep for wall instance. Sweep position is outside of its wall. Please check sweep parameters."
I'm running the 2017 version
What is going on?
Replies (7)
Message 2 of 8
Sounds like the built-in Sweep doesn't like it's settings. Post the file.
Message 3 of 8
Samantha-G
Hi @keimigassociates
Thank you for the question.  Is this a wall you created?
If so I would delete the sweeps, and see if that corrects your problem.  I have had this happen when my sweeps are offset from the wall, so Revit cannot create it.
Sam G, CM-BIM
Revit Certified Professional
Message 4 of 8
keimigassociates
Thanks!
Message 5 of 8
I would think fixing the Integral Sweeps would be preferable to removing them. That's a lot of work building Sweeps into Wall Types. Betcha the fix is easy too.
Message 6 of 8
keimigassociates
Here is the file.  For some reason the sweeps are now grayed out in the wall type editor.
Message 7 of 8
Are you talking about this Message?
Just ignore it.
You need to set your Edit Assembly Preview to SECTION.
Message 8 of 8
Samantha-G
As stated these kind of errors can be ignored.  I think you are getting it though because the sample wall 20'-0" so it is not able to create the sweeps that are above 10'-0" which is the height of your walls.
Sam G, CM-BIM
