New at revit – info.
Message 1 of 8
Please any advice on which are the best ways to learn revit? I am going to start working with this program. Any advice on books or tutorials will be much appreciated
Thank you
Replies (7)
Message 2 of 8
aRcHiTeCt.JM
… hi @Anonymous
… best way to learn … PRACTICING a lot !!
… books:
…mastering REVIT (Aubin) the BEST !!!
…mastering autodesk revit architecture (Krygiel)
…. revit architecture - no experience required (Wing)
… but first go around the forum
… there are hundreds of tips and information around
https://forums.autodesk.com/t5/revit-architecture-forum/best-revit-book-and-learning-resources/td-p/...
… also there are another thousand youtube tutorials for free
… or some paying subscriptions like Lynda.com or pluralsight… etc…
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 8
wow. so fast. thank you.
Message 4 of 8
loboarch
There is a step by step tutorial with incremental datasets and videos in the Revit LT Help.  Everythign is ths same for Revit.
http://help.autodesk.com/view/RVTLT/2020/ENU/?guid=GUID-9E9688A2-0645-4F8E-9D96-F1B76291A6C6
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 5 of 8
thank you Sr.
Message 6 of 8
dgorsman
Learn the "right" way first.  Can't emphasize that enough, especially if self learning and starting with experience in other software.  Bad habits can be hard to break.
Message 7 of 8
@Anonymous:  my response to another forum member today:
My suggestion would be to learn by doing.  Practical knowledge vs. theoretical knowledge.   I don't now what industry you are in, or wish to get it, but if it's say Residential/Light Frame on the Architectural side, then find a hard-copy set of Architectural Plans for a house and recreate them using Revit.  Or, if you are transitioning from AutoCAD, then reproduce a Project you did in AutoCAD using Revit.   Essentially the same design to documentation workflow.
So basically , design your own "course"; a task -specific course using Google to search the information you need as you need it.
Refr: https://forums.autodesk.com/t5/revit-architecture-forum/revit-courses/td-p/8798270
Message 8 of 8
georgehobel
I made the decision 1-1/2 years ago to learn Revit, today, it's all i use.  You tube has been great, Revit tutorials are good, and asking questions here in this forum.  Dont be shy, ask .  But do some searching on your own first.  That way you will better understand how to apply the answers you get.  I also have one of the books listed in that first reply, Revit, No Experience Required.  It was very handy to get me moving and getting used to the commands.  I still refer back to it as I continue to reach for the next level with my drawings.
George Hobel
Reflections of Charlotte
Residential Building and Design
