… hi @gaetanoEYV7H
... as I 've said not too long ago ...
… best way to learn … PRACTICING a lot !!
… books:
…mastering REVIT (Aubin) … the BEST !!!
…mastering autodesk revit architecture (Krygiel)
…. revit architecture - no experience required (Wing)
… but first go around the forum
… there are hundreds of tips and information around
… also there are another thousand youtube tutorials for free
… or some paying subscriptions like Lynda.com or pluralsight… etc…
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
My suggestion would be to learn by doing. Practical knowledge vs. theoretical knowledge. I don't now what industry you are in, or wish to get it, but if it's say Residential/Light Frame on the Architectural side, then find a hard-copy set of Architectural Plans for a house and recreate them using Revit. Or, if you are transitioning from AutoCAD, then reproduce a Project you did in AutoCAD using Revit. Essentially the same design to documentation workflow.
So basically , design your own "course"; a task -specific course using Google to search the information you need as you need it.
As you can see from the description, Revit offers several advantages to architects and engineers.Many of these benefits come from how closely it integrates with the BIM concept.However, the software itself also has a few advantages you should keep in mind. Let’s take a look at some of them. Benefits – Parametric Components No Repetition Landscape Design Energy Efficient Design No Paper Documentation The Huge Library. If you want learn about online Revit course then visit CETPA INFOTECH online training provider.
I've created series of videos for my students to use during the lockdown/distance/learning year. You are welcome to check it out. https://youtu.be/UHzuxeJUJRI I cover very basic stuff, but I cover them in detail. The link I provided is just to one of my video. You can browse the channel to find more.
