PLEASE HELP URGENT!!!An unrecoverable error encountered IN ALL VERSION
Message 1 of 28
Hi, I have problem with revit 2019/2020 since yesterday. I not able to open any revit file include families (rta), so I tried a lot of solutions from forum but it does not work and I decide to uninstall clean and download from website. However, it was not working, I also donwload 2020version to try but it failed, totally not working, it pop yup the phrase " An unrecoverable error encountered..."
REPORT CONTENT:
dmpuserinfo.xml
dumpdata.zip
journal0004.txt
ANY SOLUTION? PLEASE HELP!!!!!
Replies (27)
Message 2 of 28
Post the journal file...
Message 3 of 28
Please check it, I have attached the journal file. thank you
Message 4 of 28
Update to 2019.2.1...see if that helps.
Message 5 of 28
but this is the latest version
Message 6 of 28
Journal says you have 2019.0.1 installed... 2019.2.1 is the latest.
Message 7 of 28
I open to autodesk desktop app, it state " your available updates are install" may I know where can I update?
Message 8 of 28
It come out something like this when I try to download updates from wesite
Message 9 of 28
I would suggest uninstalling....download and install the 2019 standard install.  Do not install the 2019.0.1 update.
Where are you downloading from?
Message 10 of 28
I have just uninstall 2 times, download from autodesk website with student account.
I could not find where is the 2019.2.1 version, all I can find is the add-ons, where can I updates?
Message 11 of 28
It is important that you disable the anti-virus software. Verify on the Processes tab of the Task Manager that the anti-virus program in ended.
Also, it could be the "Clean Unistall " procedure you followed. There are a couple of recommended workflows published that lack, IMO.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 12 of 28
Hi I uninstall by following the instruction and now to reinstall, how can I choose not to install 2019.01? Please check attachment.
Message 13 of 28
Message 14 of 28
Do a clean uninstall of the software using the procedure in the Link I provided above.  Also, what is stats on you computer (i.e. OS, available harddrive space, etc.)?
Message 15 of 28
Tomislav.Golubovic
Absolutely send the error report to Autodesk, I had this for my 2020 and I submitted a handful of error reports and got an email back the next day from someone at Autodesk who walked me through the fix. I'd highly suggest sending that report with your email address.
Message 16 of 28
I've done the clean uninstalled and successful reinstall now, the desktop is new, no problem with harddrive etc.. and anti virus has been disable. However, still not able to use.
Message 17 of 28
hi, I have update to 2019.2.1 it still not working, please check attachment
Message 18 of 28
I'm betting it is Registry related.  Could be Security Permissions as well. It's important to install as Administrator.  Bottom line: do a "Clean Uninstall" per the Link I sent you.
Still, would be nice to know about your computer specs.
Message 19 of 28
How to solve with "security permission"?My computer is only one user without others family members or users, it is download as administrator, I have follow all the instruction from the link you gave before reinstall, Im sure it is clean uninstall. I will attach the specs for you.
Message 20 of 28
Windows 10 Home? Hmm? I wonder.  Not listed under minimum system requirements.
Also, how much harddrive space is free?
