Nested void
1 REPLY 1
245 Views, 1 Reply
Nested void
Hi all
I am working on this family where I have nested some generic model void elements but when I try to use the cut geometry tool it does not cut!
when I load the void into the project it can cut normally using the cut geometry but not in the family editor.
what am I missing?
1 REPLY 1
RDAOU
Hi Marie Joe
You need to use Generic Model Face based family for the voids. In this family you can define the void to cut a "Host" which in this case it is the face you place it on. Only those voids can be used/nested to cut other elements in the Family Editor Environment.
The family editor will not see the void as a cutting element/geometry when it is created using the regular Generic Model to create the void then nested into the parent family. In such case the void will behave literally as "Nothing" ... see screencast below
Forma Design Contest
