Any knowledge is appreciated.
I created a door family with multiple nested shared components. I loaded the host family into the project, then when I go to place the door on the wall, all "shared" nested components are dumped to the project center until my cursor hovers over a wall and it disappears.
While not a deal breaker, since the shared components disappear after I end the tool, it is rather annoying "quirk" I would like to avoid if possible.
This was not an issue before with non-shared nested components.
I am working in Revit 2022. All nested "shared" components are not surface or workplane based if that changes anything.
![Door parameters floating.jpg Door parameters floating.jpg](https://forums.autodesk.com/t5/image/serverpage/image-id/1215641i1B45088638A550C8/image-size/medium?v=v2&px=400)
