Hi François-Gabriel,
Thank you very much for your answer!
> But do you know that you can make profiles parametric?
Thank you. I know - but wanted to try a more thoroughly hierarchical approach this time. So parametric profiles (and a flat hierarchy) currently seems to be the way to go.
> Yes, to my knowledge there is no point in nesting a profile in a profile.
Hm. I disagree, of course, as I would not have posed the question if I would not think that nested profiles might be an interesting approach to my design problem 🙂
But this might be because I come from a computer science / computational design background where a more thoroughly structured hierarchical approach to problem solving is natural. In architecture, however, there is a different tradition to problem solving caused by an eternity of being forced to use more traditional, relatively inflexible tools.
(To prevent the logic answer "so why don't you use programming or Dynamo?": Unfortunately the company, I am currently working for only provides Revit LT - so no access neither to the Revit API nor Dynamo...)
> Revit allows you to insert only detail items as a proof of concept.
Indeed, Revit's approach to parametric design sometimes feels like a "proof of concept": It is possible to prove something by showing just a single working example 🙂
I have to realize that I expected a more thorough, "from the ground up" approach to parametric design before starting to work with Revit.
Anyway, sorry for the rant 🙂
Probably this is the result of Revit's history: I suppose the first version of Revit was motivated by a more "traditional", drawing based approach to design rather than parametric thinking as guiding paradigm. A large part of Revit's "parametric" behaviour looks like having been integrated in retrospect as solution to some practical need rather than like being part of the initial software design concept.
This is just the beginning of a new design aera - and already a quite impressive one.
Cheers,
Dietrich
