Hi everyone;
So... We have these families which pin the location of plumbing fixtures, and later we have to place the actual plumbing fixture so we can schedule it. I thought that interchangeable components could save us some time but I can't figure what is going wrong with the trio attached, as I followed the protocol that worked for other families.
As I place the mother family in a project, the nested component "can't use this type in this host". They're all face-based components.
Thanks in advance.
Rodrigo Bezerra
Solved by piotr.bocian. Go to Solution.
The problem is with pipe connector within nested families. There are two solutions:
1) Remove connectors from nested families and add in master family. I recommend this, because with connectors within nested families are a lot of issues, e.g. there is no way to connect a pipe manually.
2) Create nested families as not face based.
I hope these help.
Rodrigo Bezerra
